Unlike the simple transition to a ‘new to the pilot’ aircraft when technology that looked and responded to pilots in much the same way usually went without big surprises, now each avionics manufacturer has their own buttonology and screen presentation. To complicate things further, generational shifts in avionics glass packages may retain the “feel” of older versions, but differ in less-than-obvious ways.
Then there’s the failure mode problem. Who among us recall the uncommanded acceleration and loss of operator (driver) control in some of the earlier models of drive-by-wire cars? Faults were difficult to replicate so several fatal accidents occurred before the problem was acknowledged as both a software and hardware problem.
https://www.autosafety.org/wp-content/uploads/import/Belt%20An%20Electronic%20Cause%20for%20Sudden%20Unintended%20Acceleration.pdfWe are unlikely to return to cables, pushrods, hydrolics & analogue instruments so the ‘fix’ to complex presentation of flight information and virtual controls may be more helper AI and autonomous aircraft. Perhaps those fixes will also include (I hope!) lots of redundancy and checksums to push bad outcomes from software or hardware errors close to that Holy Grail of zero faults.
https://www.autosafety.org/wp-content/u ... ration.pdfWhile I’m not quite ready, I expect my grandson won’t give much thought to hopping in a fully autonomous machine on the ground, on water, or in the air.
