Are there any regulations or physical limitations for moving instruments around the panel? For example:
Does the FAA prescribe that certain instruments must be placed: high/low, left/right or center?
Do certain pitot-static instruments have to be placed on the same side of the panel, as the pitot-tube/static port located outside on the fuselage or wing?
Do navigational instruments need to be located within so many inches of the Nav/Comm rack or GPS display?
Can dual instruments, such as airspeed indicators, be mounted apart, yet share the same input source?
How much slack wiring / tubing is normally available behind a mounted instrument?
Does this normally need to be replaced in order to re-locate that instrument?
Thanx, Dave.
P.S. - I've seen so many different instrument panel set-ups, but, wanted to know if location is truly just a matter of personal preference?
