Marty--what do you have now, and which model are you going with?
Lance
john54724 wrote:For the 2 vs 3 blade question; first our 2 and 3 blade props use exactly the same blade and exactly same diameter, so with that as a constant, the 3 blade really should have 280 or more HP to work better than the MT 2 blade.
Dominion Propeller in Anchorage is a great prop shop and has just completed the very difficult MT training to be approved to service and overhaul MT props. Just waiting now for FAA approval of application of license.
Here is a couple of YouTube videos I made last week while in Anchorage showing the MT prop with reversing option on a 200hp PA-18. Real fun and good on floats too.
http://www.youtube.com/watch?v=l2zfnPakVjU
http://www.youtube.com/watch?v=oYIvOFsGNOY
john54724 wrote:Russ said it exactly correct. The MT prop is designed to have best thrust at lower RPM's. FACT: we attached a float plane with IO-520 to a digital strain guage and recorded measured static thrust with several props by starting at full power and prop at max rpm. Then on all, dial back rpm control and record thrust. Surprise!! Max thrust in the MT was obtained about 2600 +-. And the recorded thrust on the MT was higher than the 80 or 88" 2-blade props on the same plane (and made a LOT less noise). Many experts out there tell owners to run oversquare for best performance and endurance. I won't argue with Lindburg et. al..
And 'yes' a money back satisfaction gaurantee is offered on all sales.
Isn't the 403 mac the prop that has some resonance issues at certain rpms or restricted rpm ranges?
