a64pilot wrote:Dean,
I think you are exactly right, but I'm not sure that's it's me that is confused. As a mechanic, if I change the basic weight of an aircraft, then I have to recompute the aircrafts basic weight and moment.
But as a pilot, if I drop off a passenger, add some fuel and ice chests, I don't have to find an A&P to compute weight and balance. I believe as a pilot I'm required to ensure that the aircraft remains within CG and gross weight limits throught all phases of the flight. If I can't legally compute it, then how can I do that.
Now one way to do that is to compute several weight and balances, reference them and determine that you fall in the middle somewhere and therefore are within CG and gross weight limits.
BTW, I'm "typing" on my EFB tablet with a stylus, so it's worse than typing on a keyboard with one finger, please forgive the mistakes, slowness and short, choppy sentences.
[/code]
A64
Think of it this way...
Consider the weight of an airplane as a "dead load"...and the stuff you put in it as a "live load"
A mechanic needs to weigh a plane and calculate its arm and fill out a W&B sheet and sign it for the "dead load" part of the plane. Seats are part of the dead load as they are intended to be a part of the plane. So, when you remove a seat, you don't need to re-weigh the plane but you need to have the mechanic subtract the weight of the seat from that particular station (arm) and then sign the "seat out" weight and balance.
So, when you as a pilot start loading fuel, passengers and gear into your plane you will use whatever "base" W&B fits your particular case. If you flew 4 people out, you'd use your "seat in" sheet, their weights and fuel...and you do that yourself...no mechanic or signature needed. When you removed the seat and stuffed the plane full of fish you'd use the "seat out" base W&B and go from there, again, no mechanic or signature needed.
Same thing for "floats, seat in" "floats, seat out"...etc. all which need a signature and need to be carried in the plane.
