Backcountry Pilot • Mystery thermo style C-180 breaker
9 posts • Page 1 of 1
My 54'C-180 instrument panel refurb is almost ready for wire, breakers and switches.
Heading to the avionics shop next week. One question remaining is a mystery thermo style breaker as removed. I can not find reference to it in the parts book or wiring diagram, however I suspect it is part of the pitot heat circuit. The engraved text on this electrical component is Klixon CA-2, Spencer Themostate Division. Anybody out there know more about the function of this mystery component which emerged from behind my old lower instrument panel.
Thanks
54c180 offline
Aircraft: C-180
Re: Mystery thermo style C-180 breaker
54c
My first 61 Int. Harvester Scout 80 had one hidden underneath the dash real similar. When it tripped at night ALL THE LIGHTS WENT OUT, wait a bit and they would come back on. Push the red button too soon and it would say no-no and pop off again.
Yours is a 2 to 40 amp open frame auto-reset. Will try to attach link.
Are there any other numbers on the sides??
http://www.sensata.com/klixon/circuit-b ... rmal-c.htm
Do you remember what was hooked up to it? Could be a generator overload trip.
EDIT-2 Your pitot looks like it should be - AN5812-1 orig. mil.spec. = 120 w min.
Does your panel have a pitot switch label? - hopefully a push - pull Klixon also.
Scanning the net comes up with a range from 10 to 25 amp CB for a pitot. Takes more current at initial warm up.
Gotta be someone here knows more.
Best for now
Trim
Trimtab offline
Trimtab
It can be true, even if it didn't happen - Ken Keasey - mostly*
Man invented language so he could hide the truth from others - Tallyrand - sort of
glacier offline
glacier has it right. Back in 2008 there was discussion on the C170 site about a similar breaker in the same vintage 170's and early 172. It is for the Turn and Bank, and the stall warning.
bat443 offline
There is an auto-reset circuit breaker behind the panel. In my 1953 model 180 it's located adjacent to the master switch. It is wired directly to the master-- when the master is on, the CB is on. No way to manually pull it. It is in the circuit with the turn-and-bank and the stall warning horn.
I have a 1956 owners manual here at home, in it that circuit breaker is shown at the end of wire #22 in figure 38 "electrical wiring diagram", shown on page 6-15 in the "Care-Responsibilities" section.
Thanks for the responses.
Mystery solved ...
I do appreciate this BCP forum and the positive input from members.
Cheers
54c180 offline
Aircraft: C-180
If I remember right the Nav light flasher looked very similar.
PAMR MX offline
54c180 wrote:Thanks for the responses....I do appreciate this BCP forum and the positive input from members.
See Zane, I'm not always a nay-sayer. =D>
