Ardent wrote:Strange request, but a 185 on Edo 2960s, anyone know the tail height sitting on ground, and the height under the wing? Not easy to do without the same plane there to measure, but debating hangarage and can’t measure it.
I'll try to get a number for you. I have a customer running CAPS on his 185.Ardent wrote:Wonderful, thank you both, my door is 12’, and I’ll have to find a way to deal with it, maybe ramps for the beaching gear to tail dip as I put the rudder under the door (rafters are higher).
Longshot… but just incase anyone has CAP3000Es on their 185… would love to know rudder tip height and underwing clearance (isn’t the only plane in the hangar). Inches matter in this with a 12’ door so figured I should ask, I suspect the CAP3000s will be slightly taller than the EDO 2960s, deeper body to the float I believe.
13.5 feet.A1Skinner wrote:I'll try to get a number for you. I have a customer running CAPS on his 185.Ardent wrote:Wonderful, thank you both, my door is 12’, and I’ll have to find a way to deal with it, maybe ramps for the beaching gear to tail dip as I put the rudder under the door (rafters are higher).
Got an exact number for you, he re-measured today and it's in your favor. Sitting on the ground it is 11'4".Ardent wrote:Ouch! Appreciate it, didn’t think it was going to be a foot taller.
Yes, it's a 185 on CAPs.Ardent wrote:Niiiiiice! That’s a big deal, as it means I could squeak it in the current hangar. Really appreciate that, just to be clear this is the CAP 3000s equipped machine?
Henny wrote:I will be pulling my 185C on 2960's out of the water this week and should be able to take some measurements once it is sitting on the ramp...
