http://s1145.photobucket.com/albums/o517/moose233/
It's at 86WA Graham-Kapowsin. I'm going to get some dual in it at Scappose then bring it home.
Hooray! I'm headed down to the bank to get all the money in one pile. Later
EB
That's a cool name isn't it.mountainmatt wrote:Congrats! Patches looks fun to fly.
Emory Bored wrote:What kinda wheel is that?? Good year? Whee?
How much trouble would a guy get in with big tires on that. I haven't seen the logs. Hopefully it's had them on there at some time in the past. It came out of a life in Alaska.
Thanks Bob, long time no hear from. I bailed on Hot Air so I haven't heard from you much.z3skybolt wrote:Congrads...
You are going to have fun!
Bob
She'll put spring in your step!
All good info Whee. The fuel system was the last thing I thought about last night before bed and the first thing this morning. The wing tanks are the little 4.5 gal Timm tanks, not the 11.5 gallon tanks called for by AD 50-37-01.whee wrote:It appears that the plane has both wing tanks and the fuselage tank; I'm not familiar with that configuration so I couldn't say if it does have fuel system problems. If it had only wing tanks then it should have a valve in the bottom center of the panel (like where you trim crank is) or one each side of the cabin, one by the pilots left leg and one by the passengers right leg.
The shoulder harnesses look like they are attached to the rear carry-through. I've seem installations like that but can't remember if they were by STC or multiple 337. Combs is familiar with that type of install I think.
The carb heat on take off is for fuselage tank equipped Luscombes that have greater that 65 hp. It is to limit power so the carburetor does not get above the head provided by the tank. No need to use it with wing tanks.
The plane already has the holes drilled to inspect the carry through spars. They are located on the outside of the fuselage and drilled through the skin so you can see into the spar channel, can't remember how many but they are about .5" holes that are a couple inches apart. There is no need to remove the wings but be sure to cover the holes to keep water out.
I'm so naive sometimes. Anybody got a bridge to sell? I'll call Doug at some appropriate hour this morning and put him on the clock to look at the photos. I wonder, back a few years ago a guy could do just about anything he wanted on a 337 or of course a one time STC. If you blow up this photo http://i1145.photobucket.com/albums/o51 ... 010924.jpg and look down in the left corner you'll see a placard partially hidden by the radio. This was maybe a requirement by some FSDO as part of a work around using the Timm tanks for the AD? Wag aero currently has a proper RH tank but there was a long period when they were NOT available. Local FSDO's used to be equipped with lots of smart dudes that would make this thing work. This mod may even be on a pre 1955 337. I need the dang records CD but there is no time to get it before I fly up there. And you're sure right about the shoulder harness' attachment. That's a red flag spotted by several wags. They are nice but not required equipment. What else to attach to? Cables run back to the tailwheel spring? Just kidding.....sorta. About tailwheel springs, that's a Scott 2300 on there. Most of the go fast Luscombes use the 2000. This airplane could be parted for far more than the purchase price.
