mtv wrote:Hammer wrote:I've had three complete electrical failures...all a long ways from home, and all requiring sustained flight above 12,000 feet to get home. It's interesting enough to watch your electronics fail as you fly along...loosing engine power on top of that? NO THANKS!
I'll stick with magnetos. In this case I think simple is superior.
Man, if you've had THREE complete electrical failures, you need to spend less time dinking around with knives and more time working on your electrical system.....
Hey...if you've got a way to know when a generator is going to fail without the day and a half it takes to pull it off and disassemble it, I'm all ears! I just spent seven hours getting the damn thing back on. Three bolts, three electrical wires, two cotter pins and one safety wire and you can't get your fingers on a single mother-loving bit of it. I could do it again tomorrow in only four hours, but by the time it needs rebuilding again I'll have forgotten all the tricks...magnets; super glueing screws to the screwdriver; silly putty to hold the washers in place; pre-marking the orientation of the cotter pin holes; attach the ground wire before hanging the generator or spend two hours trying to start a single 1/4" screw...
I recon I've had a bit of bad luck when it comes to electricity, but those failures cover two airplanes and 1,800+ hours on equipment that's god-knows how old, so I'm not
that surprised.
I wouldn't tell anyone that they are wrong to fly behind electronic ignition, but I I have reasons that I wont...at least not anything I'm currently aware of.
Innovation is good. If you can have both reliability and performance that is great, but if you have to pick between the two, I'll go with reliability every time. My opinions are colored by my experiences, and my experiences with aircraft electrical systems are that they are not very reliable, and when they fail they fail all at once without warning signs.
Since all my failures have been far from home, the redundant magneto is not much comfort. I'll fly 700 miles with no electricity, but not on one mag. The cost difference between being able to hand prop and get home for repairs vs have them done in the field is tremendous...thousands of dollars when you figure in the alternate transportation to get back home and get to work while you hire someone else to fix your plane, then come back to get it. If electronic ignition came with free instillation, halved my fuel consumption, and doubled my power, I'd have still lost money on the deal. Most folks wouldn't have...but I would.
Also, it's routine for me to fly out of strips where losing half my spark is going to be a very significant safety-of-life issue. Granted, that's a real small percentage of the total flight hours, but given the consequences, any increase in performance or economy is not worth even a small reduction in reliability. To me.
I'm aware that magnetos can fail...lots of moving parts...lots to go wrong. But they've been around forever, and if you do your mag-checks with your brain engaged and adhere to the recommended service intervals, they're pretty bombproof. Anyone who neglects their magnetos deserves what they get. At annual inspection, if the mags aren't due for service, but they will be by the next annual, I pull them and service them ahead of time. That's a no-brainer to me. A few hundred more dollars in the yearly airplane budget is of no consequence when dealing with the things that keep the engine running.
As for the reliability of electronic ignition...well it depends. Just a couple months ago our Mini Cooper went tits-up on the freeway. Massive power loss, belching black smoke... bad enough on the freeway, but the sort of thing that would have you squawking 7700 and wishing for a diaper if it happened in the air. Turns out it was due to a single bad cell in the battery, nothing else. The entire output of the engine went to hell because of one bad cell inside a lead-acid battery. Now it's flat out amazing how much umph they can get out of that little engine, and that performance-to-complexity matrix might make sense in a car, but I wouldn't fly behind it.
If you include oxygen sensors as part of the ignition system then I've had another half-dozen engine malfunctions that would have been life-altering events in an airplane. How many of them would have been eliminated by mandatory replacement intervals I can't say, but that's another thing I'm not interested in getting into with my aircraft.
It reminds me of running handgun combat simulations...people show up with all sorts of fancy equipment...$5,000 race guns, wildcat loads, every sighting device, grip, lanyard and trigger modification you can imagine. As the course progresses and people realize that a single misfire or jam or malfunction is infinitely more catastrophic than a slower lock time or less precise sight picture or less destructive load, the weapons of choice get simpler and simpler. In the end everyone is running a completely unmodified factory gun in a boring caliber eating factory ammo. Simplicity and reliability beat out performance and speed when your life is on the line.
Would I take a 10% increase in economy and a 10% increase in HP in exchange for being able to hand prop the engine and know that the ignition system works as long as the prop turns? No... I wouldn't. A lot of people would and that's fine, but not me.
If someone makes a electronic ignition system that's as reliable and simple and system-isolated as magnetos I'd gladly consider it, but only then.
That's just my take on it...other pilots have had different experiences and will come to different conclusions. But I'm a very big fan of the primitive, simple, reliable, magneto.
