A couple of 8.5 x 6's will add the sex appeal I'm looking for at the front end but still looking for something to pretty up the tail end other then a full blown BBW, any ideas on offer for a 170
Please & Thank you
hotrod180 wrote:If you already have a Scott 3200,
maybe a bushwheel wide fork kit
but with a 400x4 "glider tire".
Spdcrazy wrote:hotrod180 wrote:If you already have a Scott 3200,
What's the benefit of the glider tire?
Mike I'm curious if theres anyway to strengthen the tail spring mount? I agree that a stronger spring is great, but that just transfers more load forward. I've seen more then one with cracked mounts...mtv wrote:Call Airframes Alaska and order a 3214T tailwheel steering arm, along with an upper and lower dust shield for same. Call Univair and order an L-19 (Cessna) MAIN LEAF of the tail spring.
Disassemble your tailwheel, clean it up, lube it, and replace that wimpy stock steering arm with the 3214T arm. Reassemble tailwheel. Now, pull that wimpy ass tailspring off the plane and discard both the main leaf and the smallest (shortest) leaf. Replace the main leaf with that L-19 main leaf. It’s thicker than the original, which requires that you lose one leaf. The short one is pretty useless anyhow.
Reassemble everything with all new hardware....do NOT reuse any of the bolts.
This will seriously strengthen your tailwheel assembly. The 170 tailspring is too wimpy, and I know of a few that broke at inopportune times. The L-19 main leaf fixes that without making it too stiff. The bent steering arm is MUCH stronger, and simply won’t bent, even if you get shimmy. Serious piece of work that arm, AND it gives much better steering geometry.
Now, if you’d actually like your 170 to steer even better on the ground, attach a piece of aluminum angle ( 1 inch will do) about 8 inches to a foot long across the steering attach points on your rudder. Use the holes where your tailwheel steering cables are attatched now to attach the angle. Drill a hole in each end of this new steering arm, and attach the steering cables there.
This mod will provide MUCH better steering authority, without being twitchy.
Now, all this may not LOOK that cool, but trust me, improved steering and stronger tailwheel components will be a big benefit. I once received a call from a friend who’d landed on a mountainside strip and broke his spring. I flew him my original spring main leaf to get him home, and he did the spring mod when he got home. The 170 has few serious flaws, but in my opinion, that whole tailwheel assembly needs some help.
Scolopax wrote:Spdcrazy wrote:hotrod180 wrote:If you already have a Scott 3200,
The glider tire has as large of a contact patch as the baby bushwheel for flotation, lasts forever on pavement and cost less than fifty bucks to replace. I haven't taken mine off in years. It's the perfect tailwheel setup IMHO.
You do still need the wide fork. The tire is just cheaper and wears longer than the BBW.Spdcrazy wrote:Scolopax wrote:Spdcrazy wrote:hotrod180 wrote:If you already have a Scott 3200,
But you have to get the wife fork I assume right? Just a cheaper option for the tire replacement? My stock 3200 has a nearly gone tore.
