Tue Feb 26, 2019 12:55 pm
Some thoughts from someone who hasn't instructed for some 32 years, but who was relatively busy as a part-time instructor for the 10 years before that:
Don't think about buying an airplane until you've obtained your certificate and have had the opportunity to fly for awhile afterwards. As was said, both take some learning, so becoming a pilot should be the first priority. Unless you have avgas flowing through your veins, you'll find that learning to fly is hard enough, without the additional work of learning to be an owner.
Learn to fly in an easy-to-fly airplane. There's a whole lot more to learning to fly than learning how to land a tail dragger, which can take extra hours depending on your skill acquisition. My choices would be a 150/152 or a 172. Either is pretty easy to fly, so that you can get your skills and abilities that you'll need to obtain your certificate without the extra work of more difficult airplanes. And actually, either isn't all that bad in the back country, until you get into pretty rough strips or actual off-strip work, where the nose gear is probably too fragile. I don't hesitate to take my P172D into grass or gravel strips, for instance.
Then after you have your certificate, figure out your actual mission. For instance, it may seem romantic to focus on a Super Cub, which is certainly a great back country airplane. But it holds two and baggage. What if by then you have a bambino and you and your wife want to go places in the airplane? Or the reverse, you decide that a Bonanza is your ideal airplane, but your wife doesn't want to fly and neither do any of your kids. Now you're over-airplaned. Or perhaps you've discovered that you really want to obtain your instrument rating and own an airplane that is reasonably capable in IMC. It takes awhile to decide on your actual mission and what airplane fits it. I think every new pilot goes through this, trying to figure out and match actual mission to a reasonable airplane to fit it.
Just using me as an example: after I obtained my private in Alaska back in 1973, I just knew that with my family of 4 and dog, a 172 would work just fine. But then I moved to the high country of Wyoming, and rapidly learned that a 172 was too anemic for that load. But a 182 fit it well, so that turned out to be the first airplane purchase, in partnership. My partner actually drove the next two airplane purchases, as he "had a need for speed" that led us to a TR182 and then a T210--but he also had more financial wherewithal that I couldn't match.
And that's another issue to consider. Some airplanes just cost more to buy and maintain than others, and that's part of the mission.
I've had my P172D for 15 years now, and it has fit my overall mission very well. I don't go into back country areas very often, but I do land at grass and gravel strips, and it works fine for that. I rarely fly with more than one passenger, but sometimes I do, and with a low fuel load, that works. My Molly dog was my most frequent passenger, until I had to put her to sleep this past November, so the back seat was mostly her domain. I suspect another dog will find it just as comfortable, sometime in the future. I have been to many campouts in my airplane, and while packing was often tight, I got it all in while staying within my airplane's weight and balance. It's not very fast, but 115 knots gets me there quick enough most of the time. It's well equipped for instrument flight, and I have flown it many hours on instruments.
And finally, at my age, I really prefer an easy to fly, fairly simple airplane, which my airplane is. It's a good little airplane, for my needs and wants.
So back to the beginning--learn to fly in an easy to fly airplane, get your certificate, fly around for awhile, then decide what airplane is best for you and your circumstances at the time.
