northernguy wrote:Normal and Utility Categories refer to the Certification Category of the aircraft, based (largely) on the demonstrated flying characteristic of the aircraft. The terms do not refer to an aircraft's intended purpose of mission.
For example: The 172 is certified in both the Utility and Normal Categories. It is restricted to the Utility Category if spins are being conducted. This restriction in the 172 is a function of gross weight and CofG. In other aircraft the category may be a function things such as trim position, strakes, weight, balance or a combination of any of these factors.
In the Utility Category, one of the characteristics the aircraft (the 172 in this example) must demonstrate is the ability to recover from a spin without control inputs after no more than three rotations in the spin. This is one of many of the characteristics that must be demonstrated in order to obtain a Utility Category Certification. In the Normal Category, spin recovery can rely on pilot input in order to recover from a spin but the aircraft must recover from the spin after a set number of rotations (I think it's no more than 1.5 rotation but my memory could be off on that).
There are many aircraft that do not have Utility Category Certification. They are certified in the Normal Category. These are often (but not always) easily identified by a placard that states something to the effect that "Aerobatics, Including Spins, are Prohibited".
Hope this helps.
Not quite. Actually, the difference is in permissable load factor. Here's a "sort of" description of the differences:
Category
Normal Category is a certification category. This category has a maximum G loading of +3.8 G's (positive G's) -1.52 G's (negative G's). Usually spins and other maneuvers that exceed the normal flight envelope are prohibited.
Utility Category is a certification category. This category has a maximum G loading of +4.4 G's and -1.76 G's. Aircraft in this category are approved for maneuvers that are not acceptable in the Normal category. Spins are required for certification in the Utility category, IF the aircraft model is approved for spins.
From Part 23:
§23.3 Airplane categories.
(a) The normal category is limited to airplanes that have a seating configuration, excluding pilot seats, of nine or less, a maximum certificated takeoff weight of 12,500 pounds or less, and intended for nonacrobatic operation. Nonacrobatic operation includes:
(1) Any maneuver incident to normal flying;
(2) Stalls (except whip stalls); and
(3) Lazy eights, chandelles, and steep turns, in which the angle of bank is not more than 60 degrees.
(b) The utility category is limited to airplanes that have a seating configuration, excluding pilot seats, of nine or less, a maximum certificated takeoff weight of 12,500 pounds or less, and intended for limited acrobatic operation. Airplanes certificated in the utility category may be used in any of the operations covered under paragraph (a) of this section and in limited acrobatic operations. Limited acrobatic operation includes:
(1) Spins
(if approved for the particular type of airplane); and
(2) Lazy eights, chandelles, and steep turns, or similar maneuvers, in which the angle of bank is more than 60 degrees but not more than 90 degrees.
So, a Utility category airplane is certificated to higher load factors on the airframe. Many Utility category airplanes are certified for spins, but not all are.
A utility category airplane is, by definition, somewhat stronger than a Normal category airplane, but the differences aren't huge.
An example of a manufacturer using this as a sales pitch was Aero Commander and Bob Hoover demonstrating the airplane's strength, since it was certificated in the Utility category. Interestingly, Hoover flew the airplane so smoothly in his demonstrations that he never even came close to exceeding the Normal category certification limits.....
