Backcountry Pilot • Obstacles on final
Obstacles on final
6 postsPage 1 of 1
Obstacles on final
Friend's strip with some obstacles on final
motoadve offline
Aircraft: Cessna 182P
CJ 6 Nanchang
Cessna 170B
Re: Obstacles on final
Nice work.
Crzyivan13 offline
Aircraft: 1957 Cessna 182A
That looks pretty good from rainy BC:)
As always, you do a fine job. I exaggerate a bit at times, but coordinated turns near the ground scare me. There is often stuff down there. A rudder turn, up to about 15 degrees, is often safer. On takeoff, it often works to make the cross controlled rudder turn in ground effect. Landing, it is just a wings level slip.
Something to consider on strips with crooked departure and/or approach paths. You did not appear to be too close, but coordinated turns on final often cause problems with longitudinal alignment as well.
I saw that last video clip back right after it happened. Hard to believe that the pilot was shooting for the very end of the strip, right next to the crossing road, without checking for road traffic. There's an airport near me set up sorta similar-- crossing road right at the edge of the pavement and displaced threshold markings on the runway to compensate. Occasionally I like to land on the very end-- but I always check for vehicle traffic.
(what's the old rule-- check left, check right, then check left again?)
6 postsPage 1 of 1
