I also was one of the last ones in on this occasion, as Gump recommends, so even if you are second or third in stuff can still happen even with years of experience landing ahead of you, be prepared, I wasn't, Thanks Tom and Steve for your help that day, JP256 wrote:<snip>aftCG wrote:It was pounded into my head 20 years ago to make every landing a spot landing. If I'm not on the ground by the time I roll over the numbers I consider myself to have gone long. Spot landing is one of the few flying skills that will save your life if your engine packs up. Burn gas at your home airport in your plane until you can make the first turn off without any chirping or tire smoke (see skill sets outlined by people above).
Unless your runway is super-short, it might be better to make your "target" the first stripe AFTER the numbers while you're learning to hit the mark every time. It can be embarrassing (or worse) to come up short...
<snip>
I agree. Be sure to hit your spot, but the spot doesn't always have to be the start of the runway. I landed in Fort St John yesterday with a 15 mph headwind. I did not stick it on the numbers because I would've had to taxi 7000 feet to the taxiway. I touched down well after the intersection of the 2 runways, still had plenty of room and a bit less distance to taxi.Cary wrote:JP256 wrote:<snip>aftCG wrote:It was pounded into my head 20 years ago to make every landing a spot landing. If I'm not on the ground by the time I roll over the numbers I consider myself to have gone long. Spot landing is one of the few flying skills that will save your life if your engine packs up. Burn gas at your home airport in your plane until you can make the first turn off without any chirping or tire smoke (see skill sets outlined by people above).
<snip>
I agree with making every landing a spot landing, even on 10,000' runways. But I also agree that when practicing and especially when still learning before becoming 100% consistent, it's better to give yourself an "out" by aiming for a mark farther down the runway.
Some years ago, I was practicing short landings at the old 3V5, Fort Collins Downtown, consistently landing on the leading edge of the numbers, which made turning off at the first turn off 600' later pretty easy. I had no issues with doing that, but my regular CFII (whom I use for BFRs and IPCs) asked me if I would mind using a spot farther down the runway, because he had some students who might try to emulate me, and come up short. So now when I know there's no one else around, I'll still often use the numbers as my touchdown spot, but if there are any others who might be watching, I'll pick a spot farther down the runway.
BTW, my Daddy took out the mains of a B-25 at LaJunta, CO in 1944, landing just a tad short while practicing "assault" landings, what we call short field landings. The runway had a lip a few inches high--the contractor who built it hadn't filled in the area leading up to the runway. The review board exonerated my Daddy and put all the blame on the contractor. I have a series of pictures that were surreptitiously taken from the tower, of the bomber sliding down the runway, doing a slow spin before finally stopping.
A1Skinner wrote:I agree. Be sure to hit your spot, but the spot doesn't always have to be the start of the runway. I landed in Fort St John yesterday with a 15 mph headwind. I did not stick it on the numbers because I would've had to taxi 7000 feet to the taxiway. I touched down well after the intersection of the 2 runways, still had plenty of room and a bit less distance to taxi.
So I guess what I'm saying is, pick a spot and hit it. Doesn't have to be at the numbers or specified spot, just the one you decide to hit at the time of your landing.
A1Skinner wrote:Be sure to hit your spot, but the spot doesn't always have to be the start of the runway. I landed in Fort St John yesterday with a 15 mph headwind. I did not stick it on the numbers because I would've had to taxi 7000 feet to the taxiway. I touched down well after the intersection of the 2 runways, still had plenty of room and a bit less distance to taxi.
JP256 wrote:aftCG wrote:Great topic. My plane is similar, just has 60 more horses involved and a squared off rudder.
My 7ECA has the O-200, so only 35 more horses, and a LOT more weight than the Champ.aftCG wrote:It was pounded into my head 20 years ago to make every landing a spot landing. If I'm not on the ground by the time I roll over the numbers I consider myself to have gone long. Spot landing is one of the few flying skills that will save your life if your engine packs up. Burn gas at your home airport in your plane until you can make the first turn off without any chirping or tire smoke (see skill sets outlined by people above).
Unless your runway is super-short, it might be better to make your "target" the first stripe AFTER the numbers while you're learning to hit the mark every time. It can be embarrassing (or worse) to come up short...aftCG wrote:Learn to calculate your takeoff distance. Your POH will be even worse than mine, but it has some numbers. Look them up. Verify that your plane will match the book. Manufacturers of old planes were known to like a rug about cruise performance but the landing and takeoff distances should be achievable by a pilot with average skills even in an old plane. A C152 will get off the ground in half of what the book says if you fly it correctly.
Don't know about his Champ, but there is absolutely no POH (or any other pilot's manual) for my 1965 Champion 7ECA, and the later Bellanca version is useless, since it gives performance only for the O-235 powered 7ECA. I can't get anywhere near those numbers... So I've been building up a little table of cruise performance data for my own use, and trying to extrapolate the takeoff / landing data based on reduced horsepower, but it's probably nothing that would pass a "legal" review... So I'm pretty conservative at this point.
gbflyer wrote:To sum up, it's sort of like your high school sweetheart. Go ahead and commit, but keep your options open by staying on the lookout for better prospects. [emoji6]
gbflyer wrote:Have a spot in mind to land on your off airport LZ, and be able to stick it, but also be ready to bail out on it. Don't become so focused on the spot that you ignore the log laying parallel to your roll out path that is pointed right at your prop (the one you couldn't see on your drag pass).
Haha. Or have a good friend with a big helicopter!Zzz wrote:gbflyer wrote:Have a spot in mind to land on your off airport LZ, and be able to stick it, but also be ready to bail out on it. Don't become so focused on the spot that you ignore the log laying parallel to your roll out path that is pointed right at your prop (the one you couldn't see on your drag pass).
It always helps to imagine the salvage operation too, where you have to take the wings off and float everything out on a barge. Then you start thinking like "maybe I should go play where you can get access with a flatbed trailer."
Hammer wrote:Put on bigger tires if you want to play in the sand. Someone else on this forum found out the hard way that 8.50's are not enough tire for that.
contactflying wrote:All of my off airport work was with stock tires, but I didn't land in river sand. Gust problems can best be handled by dynamic proactive rudder movement and reactivate but quick throttle movement. We are responsible for the control of our aircraft in pretty severe conditions and are given controls adequate to those conditions in well designed aircraft. The control that gives the quickest response is the rudder. Wind overcoming control is usually too much reliance on the slowest response control, the aileron.
