Oil air
Tue Feb 21, 2023 10:23 pm
Any of you with substantial climbout deck angles have oil venting issues?
Are you using an oil air separator if so what's working for you?
rsrguy3 offline
72
- Aircraft: 53 pa22
55 f35
62 150
Tue Feb 21, 2023 10:57 pm
If you're experiencing more oil out of your breather system than seems "normal", regardless of deck angle I would suspect engine health. Every time I've seen a bunch of oil coming out of the breather it's either been a really hot day with the machine run hard or excess blow by from worn rings.
I'm not a big fan of oil separators that sit high on the engine and reintroduce "separated" oil back into the system. Most of the nasty byproducts of combustion are not separated out.
Halestorm offline
956
- Aircraft: C-182E Pponk
rsrguy3 wrote:…substantial climbout deck angles…
I see a Pacer in your avatar.
2854
Wed Feb 22, 2023 10:01 am
Zzz wrote:rsrguy3 wrote:…substantial climbout deck angles…
I thing rsrguy3 is referring to the C-150. That would make more sense.
Squash offline
605
Good.. I never minded being the target of a good heckle... nope not the 150 or the tripe..
rsrguy3 offline
72
- Aircraft: 53 pa22
55 f35
62 150
The field altitude is 4230'....
rsrguy3 offline
72
- Aircraft: 53 pa22
55 f35
62 150
I can hear Contact gritting his teeth and growling.
SmilinJack offline
32
- Aircraft: Husky A-1B
