Aluminum tape works good. Remember what temp water boils at, if your oil does not get that hot water(condensation) and other contaminates don't boil out plus with thick oil the engine is working harder. I work on a lot of large radial engines and most operation manuals for those say not to exceed 1000 r.p.m. until the oil is up to around 40 degrees Celsius. I still cant convert between C' or Farehiet but a good guess puts 40 around 100 degrees f'.
I own a 55' 180 and installed a oil cooler baffle that has a hinge and a plate installed on it, so I can adjust my temp up and down via a control from the instrument panel.
Hope this helps.
Dave
