Resurrecting this thread. I found it in a search, and have some data to add.
ak2711c wrote:I'd be curious to see a dyno report on the pponk to understand why they limited it to 2700 rpm. Was that where max hp and torque was reached or was that to make the FAA happy? Interestingly in the pull tests I have done on planes with constant speed props it is not uncommon for it to pull harder at 50-75 rpm less than max rpm. I suppose that is a factor of the torque curve or blade design or both.
Probably some of all of the above. Looking at power/fuel curves for the IO-520-D/F models, as well as Continental's specs, we see the following:
- Max T/O RPM is 2850@300HP, but only for 5 minutes. After that, max rated continuous RPM is 2700@285HP. They also recommend a max of 2550 RPM for cruise, which gets us around 265HP at sea level.
- P-Ponk's STC covers the 520, but also covers conversion of an O-470 which was never meant for >2700RPM. The high limit could very well be based on the design parameters of the 470, not the 520.
- They had a practical limit of props on hand, and time and money to test things. For the same reason they didn't follow through with Mogas STC, they probably didn't verify the 2850 max RPM for the direct 520 replacement.
- Max HP is absolutely achieved at 2850RPM according to Continental.
- Curiously, brake-specific fuel consumption (fuel used per HP delivered) is identical at 2700 and 2850. It gets worse at all RPM's below 2700 fairly linearly. Best BSFC is at about 2770, but only marginally so over 2700/2850.
- I've anecdotally heard of aircraft coming apart from vibration due to engine changes. Particularly with metal props and balance potentially being out of spec, it's conceivable that running a 520 at over 2700 on a 182 might vibrate things in a way not originally intended. Now, it isn't like my plane designed in the 50's had any sort of computer analysis done to prove it, but it might explain FAA limitations. A composite prop likely makes this a nonissue, but resonance can be a bitch.
If you're 337'ing the 8.5:1 pistons as I will be doing, I suppose it's theoretically possible to also 337 the max RPM of 2850 and then comply with Continental's published limits. I don't know if anyone has officially done so, or might otherwise be running 2850 just fine but not talking about it in mixed company.
