hotrod180 wrote:Not castor oil-- I'm talking wheel castor aka toe-in & toe-out.
A friend of mine is nearing the end of a multi-year ground-up rebuild of a Piper PA22-20 Pacer. he wants to make sure the wheel alignment is spot-on before flying but isn't sure what's best: toe-in, toe-out, or neutral. Anyone?
I don't know anything about a Pacer's alignment, but when my IA aligned the mains on my Cessna with spring steel gear a couple of weeks ago, it was to make it dead neutral. I suppose it would depend a lot on how much backward flex could be expected when touching down, which would tend to cause some toe-out. Hopefully, most of the flex would be vertical and not horizontal fore to aft. All that FWIW.
