I've been offered a 1960's 182 by a person whose ranch hangar/horse stall partially collapsed on the wings. It was in annual but only flown a dozen hours a year for the past couple of decades, but was in annual/kept legal as well. Both wings are damaged beyond repair, and the fuselage may be affected, but it is not visible.
Aside from the fact the engine might not be in great shape from a lack of use, everything else looks pretty good inside. The cost to return it to certificated status is simply too far out there unless he simply gives it away to someone. He wants to sell it to me cheap if I would get it flying again. I have the time to take on a project over a couple of years, but am less interested in continuing to own a certificated airplane, or putting time and effort into restoring a certificated plane.
My question is whether anyone has ever come across an Experimental 182, besides the Canada outfit? People make Experimental PA-18's and 12's partially from certified fuselages. What keeps a person from using the fantastic 182 fuselage and copying/building new wings, tail feathers, and other mods to meet the 51% rule?
The idea would be to more or less copy the existing designs for the tail and wings, making things a bit more back-country friendly (perhaps droop aileron improvements, extended cuff, a bit of extra span, other minor things). The tail could be enlarged, and a change to conventional gear could be made as well. I don't want to spend my last moments on earth as a test pilot- I just want an Experimental, solid backcountry performer to tinker with, a nice multi-year project, and hopefully some small improvements to what is already a great, fast, roomy, load-hauling airplane.
What are the regulatory bumps in the road that are different from simply building a plane from a quick build kit?
I've scoured the EAA and other websites on the subject, and can't seem to get a consistent message out of my posts or reading. The local FAA office has no interest in pointing me in the right direction either. And the crowds in the other forums seem to think such a project is a crazy idea, even though they are flying Frankenstein Super Cubs.
If this worked out, it seems like I might be able to have a fully instrumented, experimental category airplane for $25k, including a field overhaul of the engine, guessing at the cost of the home built wing and tail materials. I have sheet metal experience (non-airplane), and some other resources available. This is more of an inquiry to see if anyone else has heard of such a thing in the wild, and whether there are any obvious downsides to the idea?
