After airplane was landed on freeway a number of years ago and was purchased by our company as salvage, it has been put back together and runs strong with everything else seeming to work besides the gear not wanting to come up fully. After a few tests flights noticed some things starting to play out with the ammeter and volt meter. Basically it seems as high rpm is applied it trips the system, so from take off right away it trips.
We have replaced the over voltage and the regulator, the circuit breaker and bench tested the alternator. One of our A&P's said the alternator checked out fine on the bench. We have had it up on stands and previously had the gear coming up and locking multiple times in a row. Then test flown without success. First we need to fix the electrical issue, thinking this is tied to why the gear wont come up and lock but at the same time it has came up multiple times on the stands without the engine running...I would think that with a full charge on the system even with it having an over voltage issue that the gear would still come up and lock at least once if not a few times.
So two separate issues but thinking the electrical issue is behind it not allowing enough current to drive the pump to pull the gear up and lock?
Ideas from here pleassssse? The owner is about to light the thing on fire
Thanks
