I have had a no-name twin USB port adapter to power my Stratus 2 and iPad Mini 4 for several years. My airplane is a 55 year old P172D, with the 12V electrical system modernized with an alternator conversion. My theory has been that the devices should be powered by ship's power, and that their internal batteries should be backups. However, if I started with both of them fully charged, after a long day of flying (roughly 8 hours), I could count on the iPad Mini 4 being down to about 75% and the Stratus 2 down to less than 60%. Both would have been likely dead if they hadn't been plugged in, so the adapter was accomplishing something, just not keeping up--not doing what I wanted it to do.
I should have bought this MGF adapter much sooner. I've had it for only 3 flights now, each of them less than half an hour. I don't try to conserve power, so I usually have my Mini's screen turned up all the way except at night. I don't know if the Stratus 2 uses more power when it's busy, but today's flights were quite busy with weather and traffic. On each flight, both devices started somewhat discharged, and their charge was increased from whatever they had been showing by 3 percentage points. For such short flights, that's impressive!
My only complaint, which is really minor, is that the positive terminal, which is spring loaded, has enough oomph that it pushes the adapter out of the power receptacle. I've solved that in my installation with some electrical tape, but that might not work for everyone.
$30 well spent, and highly recommended.
