[facebookvideo][/facebookvideo]fat tire bob wrote:I had my new cylinders polished and flow matched by LyCon. They can only go so far on a certified engine,
They can clean up the rough areas on the castings but not remove any material past that. The Tech I talked to at LyCon said it should give an additional 5 to 8 HP per cylinder. This is on my 032-E2D with the RAM 160hp STC and a PowerFlow exhaust. LyCon estimated the output at between 190 to 200hp.
I did not dyno the engine so I can't prove it, but my fuel burn went up and it climbs like crazy.
Charged $250 per cylinder. Big bang for the bucks!
