SA Maule wrote:This is very good news, it widens my spectrum of available aircraft, I therefore understand that any pre 62 is the way to go, not many of those going around in South Africa but who knows, I might get lucky. For my typical mission I need 1400 lbs useful load 4 hours endurance excluding reserve, must get up in 600 feet and handle unprepared , improvised strips AND run on mogas, will probably have to add wing extensions sportsman stol goes without saying . Thank you all participants, this helps a lot, now let the search begin
1400 lbs use full load is a little tough but do able , with a little planning . This takes into account of the empty weight /options / fuel and inside cabin stuff. I weigh airplanes of all kinds and typical non wing x airplane is 1500-1800 lbs. add 1400 lbs. and you soon see 2900 + lbs. Even with wing Extensions it adds up. Trying to lift a ton and a half of airplane off a 600 ft. strip takes a big red "S" on your t-shirt . The addition of a SPORTSMAN will do wonders . Also get a LFI -Lift Reserve Indicator -and use it . Reminds me of a video I saw some time back where overloaded Maule (that had just hit a tree on landing) crashed on takeoff . Be weight conciseness of every ounce of what goes in. BTW there's a 58 182 down at ranch with For Sale written all over it. Barnstormers has a few including a 59 project that could be had in low 20s.
