Dog is my Copilot wrote:I am considering buying a tug for the 180 and want to hear what might be the best option. Back story (pun intended) here is that I had Back surgery 2+ weeks ago and am grounded for a little while for the recovery. Procedure was successful but overall my Lumbar spine MRI looks like shit and I am rethinking everything for better care of my spine. Moving the airplane is only going to get more difficult getting older.
This tug is remote controlled but also expensive and heavy. I know there are other options plus might be able to pick up a used tug for a lot cheaper.
https://acairtechnology.com/products/ac-tracktech-t1v2Josh
Hi Josh, I’ve had an AC Air tug for several years and it’s still going strong.
My situation is that I have to get a Cessna 185 and a Pitts S2B in the same t-hangar, and to do so, there is no room behind the the airplanes to get a manual towbar. The tailwheels are so close to the back wall of the hangar, there just isn’t the 5 ft or so required.
That and the 185 is a beast to haul around by hand with 20 psi in the 8.50x10 tires I have on the 185. I really needed something powered to get the job done.
The AC Air tug is low enough profile that it can come at the tailwheel from under the front of the airplane, or behind it. And there is a tailwheel kit to put on it to handle the narrow tailwheel tires. It also accommodates a baby bushwheel on the 185.
The only downside that I’ve observed is that it’s very loud when in motion. Those twin electric motors put out a lot of noise.
They are expensive, and there might be cheaper options. Given my situation I’d recommend it, however.
