7GC wrote: For what it's worth, I typically cruise at 20 in and 2300, which is about 52% power at 2500 ft according to the 206 chart.
Scolopax wrote:My experience aligns pretty closely with what these folks have found
One final note for those operating at low RPM's. This service bulletin is often overlooked. It's worth considering.
http://www.tcmlink.com/pdf2/CSB09-11A.pdf
chedrick wrote:How many hours do you have on yours now Jake?
180Marty wrote:One final note for those operating at low RPM's. This service bulletin is often overlooked. It's worth considering.
Aqua, thanks for posting that. I usually am at 20/2300 with an electronic tach but might increase rpm's a little.
mtv wrote:Seriously, don't even slow down....just install one, believe me, you'll never look back. And, that device will make developing the data that you seek SOOOOO much easier.
Scolopax wrote:At about 125 hours since the fresh engine. It's been a busy year in my wagon
A1Skinner wrote:180Marty wrote:One final note for those operating at low RPM's. This service bulletin is often overlooked. It's worth considering.
Good info in that SB, but not sure it applies to PPonks. Even most models of 520s that we run in our backcountry aircraft aren't affected by this SB. I am curious if they researched and found that certain models were more susceptible to damage from operating low or why they only picked out certain model.
