PPONK rpm restriction
I was on a 182 forum and saw this post; does anybody know if this is accurate? Just curious and may affect future considerations. I tried searching and then sent an email to NorthPoint.
PPonk engine with a Hartzell Scimitar 3 blade prop: the PPonk STC states the available constant rpm as being between 2200 and 2500
Thanks
Jack
flyingjack offline
335
- Aircraft: Husky/T206H
My guess is that it would be more of a question for Hartzell.
StillLearning offline
417
- Aircraft: Cessna 180 Skywagon 1953
There's no way that's the correct RPM limitations for that setup. It might be the range for continuous operation.
The STC holder for that propellor on that engine/airframe is the correct source for this information, hopefully you'll hear from NorthPoint..
Halestorm offline
956
- Aircraft: C-182E Pponk
From the STC:
- pponk.jpg (32.36 KiB) Viewed 1188 times
sticknrudder offline
182
- Aircraft: 7GCBC
C182
J-3
Thu Aug 11, 2022 10:17 am
I have an 86" Mac 401and it is placarded to avoid continuous operation between 1850 and 2150 rpm.
Ross
pipeliner offline
158
- Aircraft: '57 C-182A floats/wheels
I believe restriction on the 86" 401 is an RPM range at or above a certain manifold pressure, 26" IIRC. At least that what my placard says.
417
I looked up the RPM limits specifically in my STC and learned that it does not quite match my placard. However, this is specific to my Mac 401 prop.
Ross
- P-Ponk Prop RPM Limits.png (129.55 KiB) Viewed 974 times
pipeliner offline
158
