Barnstormer wrote:As soon as you start flying her you'll forget all about whether she's 40 lbs lighter or 140 lbs lighter.
denalipilot wrote:You know you're going to change the GW when you 'ponk it, anyway...![]()
Thank you for sharing each step of this process through your excellent photography and detailed write-ups. It's likely been one of the most informative threads in the history of BCP.
-DP
bigrenna wrote:DP: Unfortunately no more increase on the GW for me Ponk or not. The Kenmore Air 3190 (with the big vert stab) is the end of the line unless I want to swap out for a 185!
aktahoe1 wrote:
No doubt on the all time thread here! Over 45,000 views is insane!
denalipilot wrote:Knowing how you roll, I figured you'd go for the 520 bumpy-back case.
bigrenna wrote:Trouble is I have a low time fact engine now, so I will have to fly the piss out of her in the short term.
