Backcountry Pilot • Project: 180 Skywagon - The On-Going Saga
841 posts • Page 41 of 43 • 1 ... 38, 39, 40, 41, 42, 43
Re: Project: 180 Skywagon - The On-Going Saga
bigrenna wrote:
soyAnarchisto wrote:Nice bigrenna! I noticed you swapped out and sold your monarch caps. Is there a better option now and why?
If one has standard size bladders is it possible to install larger ones?
I still have Monarch's on. You can see em in the foreground. They are the way to go.
RE: bladder size... Unfortunately the only way to go to get more capacity if you have small tanks is go with Flint tip tanks, but that adds about 34lbs for just the tanks.
Is Hartwig not selling the Monarch extended tanks anymore?
Halestorm offline
Aircraft: C-182E Pponk
I believe they still do... But I think Greg bought an early model 180. I dont think long range tanks were available until 62'.
Very informative, thanks Greg. We learned about the process but haven't actually replaced a bladder tank in A&P school.
bushpilot490 offline
Aircraft: C-175 with 180hp conversion
bigrenna wrote:I believe they still do... But I think Greg bought an early model 180. I dont think long range tanks were available until 62'.
Yes, mine is a '56. I'm not interested in flint tanks. Thanks for the article - very cool.
Greg you have one stunning wagon!
I am very glad I found this build thread. I had just inherited an almost original 61 C185, and you just gave me a bunch of ideas for when I get it flying again. Lets all hope that I can maintain such a detailed build thread when I get to it :D
pilotryan offline
Aircraft: C185 / C310R
Falcon 900B
delete
I have recently installed Hartwig "slant tank" fuel cells in my 54 C-180.
Sure fit ok ... Also installed the vent L/H as per AD. The wings were off so all went well. The tail went on today ... it feels good :D
54c180 offline
Aircraft: C-180
delete
hotrod180 wrote:How long ago were those Hartwig tanks made? Plastic or fiberglas? It was my understanding they quit making them for the early "slant tank" model 180's.
Why don't you call Hartwig and ask them? Seems to be the best source of information about their tanks would be from them.
http://www.hartwigfuelcell.com/monarchcaps.php
Halestorm offline
delete
pilotryan wrote:Greg you have one stunning wagon!
Thanks man. I appreciate the nice words. It certainly is a labor of love!
hotrod180 wrote:I'm not really in the market for new tanks, or else I would.
At this point, my bladders are fine, so any interest in the plastic tanks is just academic.
Hartwig/Monarch's website doesn't give much info on the fuel cells, at least for the early 180's.
I do have a set of Monarch caps which I'll probably install this winter.
...and as usual, you can always count on Hotrod for a hijack and thread drift.
Bigrenna,
Can I get a long term pirep from you on how your EI CGR 30P is working? Did you get the version that replaces primary instruments in your panel? If so, which 5 did you choose?
soyAnarchisto wrote:Bigrenna,
I have been meaning on doing that for a bunch of stuff. I did the MVP-50 rather than the CGR. They share the same computer, but for me, the CGR just didn't do enough. If you have limited panel space, the CGR is a fantastic option, but if you are lucky enough to be starting with a fresh panel, I would go right to the MVP.
The long and short is the MVP was one of the single best items I installed in the Wagon. I personally like it way better than the JPI stuff and have zero regrets.
Do you have a picture posted in this thread of your completed panel? I've read it all, but I can't remember seeing it.
soyAnarchisto wrote:Do you have a picture posted in this thread of your completed panel? I've read it all, but I can't remember seeing it.
41 pages man... Just gotta dig. :wink:
In all serious... It's probably easier to find pics on my blog. http://bushwagoneast.com. That has all the content found here but is a bit more organized. There should be a link in the sidebar for "panel."
bigrenna wrote:.....and as usual, you can always count on Hotrod for a hijack and thread drift.
Sorry, that was not my intention. Offensive posts deleted.
I coulda done without the "as usual" crack though.
Beautiful. I need (want) to add a fuel totalizer - that's my short term goal rather than take the plane out of commission and do the entire panel. So a $500 instrument quickly leads to $4k for the CGR to fit in an exisiting hole and replace an old and verrrry slow EI egt/cht and give me oil temp which I don't have - and pull out 5 gauges.. Going again to the MVP would bring me up to $5.5k and take out space I was hoping to devote to an airgizmo mount for an ipad mini (instead of your 796).
Looks great. This thread is fantastic. Except for my pocket book. But invaluable for 180 update planning.
There's a search field on each topic that constrains search to that particular thread, makes it a little easier.
Also, Google, filtered by site:backcountrypilot.org
