I could use some help. Tell mom you owe me from 10 years ago when we did the same thing with the 120.
Zzz wrote:George Horn is going to give you a backrub if you pull that one off.![]()
robw56 wrote:I'll save another 15lbs by tossing the rear bench seat and installing the Atlee Dodge folding jump seats.
denalipilot wrote:robw56 wrote:I'll save another 15lbs by tossing the rear bench seat and installing the Atlee Dodge folding jump seats.
Hopefully you're not falling into the same wishful-thinking trap that I did. I called Atlee and asked how much their jumpseats weighed. I was quoted "six pounds per side". Sweet, right? Well when I got them, I realized that he wasn't including the mounting rails and other hardware. Net weight for the pair installed is about 25 lbs, not including upholstery. So, pretty much a draw with my stock 170B rear bench seat. Gains are all in utility, unfortunately not in weight.
-DP
-DP
bigrenna wrote:denalipilot wrote:robw56 wrote:I'll save another 15lbs by tossing the rear bench seat and installing the Atlee Dodge folding jump seats.
-DP
When I removed my factory bench out of the 170 it weighed in at a whopping 41 lbs. this is of course crazy heavy, but I'd take my Atlees over the bench any day. Are you sure your math is correct? Are you suggesting the rails and mounting hardware weigh 13 lbs over the seats?? I should have weighed the components, but I did that install and find it very hard to believe everything all in weighs 25. But then again, nothing surprises me anymore.
jomac wrote:....fwiw, i gave my jump seats away! dont waste the $... l simply put the rear seat back in when i need to take some pax...only takes 10 min with 3 bolts and such...the jump seats really arent much...
