Backcountry Pilot • Prop Balancer
Prop Balancer
6 postsPage 1 of 1
Prop Balancer
Anyone know if these are any good?
http://www.rpxtech.com/rpxweb/default.asp
UtahMaule offline
Re: Prop Balancer
I own one and it works. The older systems showed all the freqs so you could see a bad Cyl, or something else out of balance that may be causing a vibration. This one just shows the prop and you can remove that freq.
Skydive206 offline
Re: Prop Balancer
So, would you recommend one?
UtahMaule offline
Re: Prop Balancer
Cheaper and easier to use than this one, Honeywell Chadwick Helmuth 8500 C Plus Balancer/Analyzer.
Skydive206 offline
Re: Prop Balancer
I have owned and used mine for several years and I highly recommend it. I have balanced Rotax, Subaru, Continental, Lycoming, Walter turbine, Pratt & Whitney and Garrett turbines with 2 blades to 5 blades.
Mike
flybymike offline
Re: Prop Balancer
This type of instrument is pretty much a necessity when working with helicopters....
I don't know about this particular unit, but they DO work....
lc
Littlecub offline
6 postsPage 1 of 1
