Is it bad to leave the engine heater on for 5-10 days between flights? Would this procedure cause more condensation than leaving the engine cold then heating over night before the flight? I use a Aerotherm heater.
Thank you Rob
hotrod180 wrote:I've heard running the engine-mounted heaters 24/7 isn't a good idea,
it can cook the oil and/or promote moisture condensing inside the engine.
I used to hang a 125W heat bulb under the engine on my last 2 airplanes,
with a blanket over the cowl it worked great,
but in between the cowl flaps & the mufflers that just won't work with my C180.
Since it doesn't get all that cold around here, I've just been going without winter heat,
but we do get cold snaps (like a couple weeks ago) so it's nice to have something.
A friend of mine runs one of these, I just ordered one.
https://www.aircraftheaters.com/aircraftheaters
Keeps the engine compartment at a steady 70 degrees
scottf wrote:I think if one has the option to kick on the heater when needed the day before it is probably better than leaving it on all the time, but if thats not possible or practical leaving the heat on is way better than no preheat... heat accelerates chemical reactions but i would suspect the air is so dry in most regions where you need preheat that moisture and corrosion are probably pretty small on the things to worry about scale.
OregonMaule wrote:Is it bad to leave the engine heater on for 5-10 days between flights? Would this procedure cause more condensation than leaving the engine cold then heating over night before the flight? I use a Aerotherm heater.
Thank you Rob
I think the advantage with an aerotherm heater is that you are heating with warm air rather then probes or a pad. Once you set the thermostat it will just keep recirculating the air at a certain temperature. No different then being in a hangar. And if you crack your cabin heat open I'd bet it'll heat the cabin up as well.PapernScissors wrote:OregonMaule wrote:Is it bad to leave the engine heater on for 5-10 days between flights? Would this procedure cause more condensation than leaving the engine cold then heating over night before the flight? I use a Aerotherm heater.
Thank you Rob
I agree with Hammer's comments.
An aquaintance and his friend own a really nice C185. Three years ago he told me they "got to" buy a new engine. He said they decided to leave their sump heater plugged in 24/7 a few years prior to our conversation. After a couple of winters their cam was severely pitted and they found corrosion pitting in the top end too. He blamed the corrosion on condensation on the unheated top end. I've read that Tanis and other engine heaters that bring the whole engine to temperature don't have that condensation problem.
Since my engine just has the sump heater and my hangar is unheated I only plug it in a few hours before I fly. I also wrap the cowl & prop with multiple blankets & use cowl plugs to keep the heat in during the pre-heat process. FWIW I've seen advice in Lyc tech notes to avoid internal engine corrosion caused by leaving preheat on continuously. I also preheat my cockpit with a small ceramic space heater for a couple of hours before winter flights. I've noticed my vacuum driven gyros come to life much more quickly when the bearings aren't frozen.
Thank you Rob
whee wrote:...Sure you can blow hot air on your intake system for 30min which will get it warm enough to easily start the engine but will do zero in preventing cold start engine damage....
Hammer wrote:whee wrote:...Sure you can blow hot air on your intake system for 30min which will get it warm enough to easily start the engine but will do zero in preventing cold start engine damage....
So...while that's true enough, I'm not entirely positive that a two-hour + pre-heat is necessary, even if it is ideal. My understanding is that most cold-start damage comes from oil which is too viscous and slow to circulate, and pistons and cylinders scrubbing due to them expanding at dramatically different rates as they go from sub-freezing to hot...something exacerbated by the viscous oil not getting there fast enough or in enough quantity.
So if your oil is warm enough to flow freely, and your jugs are warm enough not to bind on the piston...what real difference does it make if the camshaft is still freezing cold? I'm talking starting up, not going to full throttle here.
No argument that warmer is better, but it's often impractical/impossible to get an engine warm all the way through in the field. I routinely pre-heat till the oil and CHT temps are above 50 (and warmer is better), then start up and let the engine warm itself by running...sometimes for a quarter-hour before even doing my run-up. I have no doubt that the internals of the engine are still cold, but I'm at a bit of a loss as to why that matters so long as they're getting proper lubrication?
I'm not a mechanic, so if there's something I'm not getting, it wouldn't be the first time. And before someone brings up the ubiquitous -40 cold-soaked engine and brittle steel, lets keep this in the perspective of most aviators and assume we're dealing with a ten-degree fahrenheit situation or thereabouts. I personally quit flying at -39 degrees:
