Purchase PPonk STC????
Have any of you purchased the PPONK STC and done the work yourself? I'm thinking of buying a runout io520 core and purchasing the paperwork so my mechanic and I can do the STC work on it. It's time to look at overhaul options so any insight would be appreciated.
TxKiger offline
256
- Aircraft: 182
Maybe talk to Steve Pierce over on Supecub.org. He is at Graham TX and did SJ's 180 a few years ago.
2313
Or perhaps Steve Knopp himself? He's very helpful, and he'll have the most current pricing.
http://www.pponk.com
Halestorm offline
956
- Aircraft: C-182E Pponk
I did. Used a TSIO-520 because that was the easiest and least expensive way to go. Sent them the appropriate carb for re-jetting.
Call Steve, he is a great resource and was very helpful.
flyfish
flyfish offline
33
Thanks for the responses everyone!
TxKiger offline
256
- Aircraft: 182
Flyfish-
Which version of the TSIO-520 did you use... the C or D or what? Just from my point of view I really like my alternator on the fan belt with my O-470R.
gunny
Gunny offline
394
Just installed an io-470d oh with c-58 prop in a 65h 180 norland stc carbureted. Flew the plane the other day .plane hasn't, flown for 25 years . Was a 3 month job put it together flew great good performances braking in oh engine. Firewall battery flat floor on interior wt was 1623 ibs float kit 3190 up gross great conversion
Cub180 offline
92
- Aircraft: Cessna 180 skywagon, Supercub pa18
Sun Feb 01, 2015 10:15 am
Not much difference between that and the Texas Skyways O 470 UTS.
2313
Sun Feb 01, 2015 12:10 pm
Cub180 wrote:Just installed an io-470d oh with c-58 prop in a 65h 180 norland stc carbureted. Flew the plane the other day .plane hasn't, flown for 25 years . Was a 3 month job put it together flew great good performances braking in oh engine. Firewall battery flat floor on interior wt was 1623 ibs float kit 3190 up gross great conversion
I really Like your paint colors on that 180K .Also looks like green tint windows all the way around. Nice!
What's the H model going to look like?
mountainwagon offline
180h friends plane I did still doing work on it paint in a year stripped now .my 180 was done 3years a go p-ponk done 5 years ago . Had problems from start. Had vibration issues . Balanced prop 2 no tried other props.fixed every thing loose on the plane.9 months ago fixed the problem.runs great now.picked up 6 kts runs smooth no need to balances prop .cruise at 147kts on 8.50 14 in Xp tail wheel
Cub180 offline
92
Cub180 what was the cause of your vibration in your pponk motor? I have a texas skyways 0470U that I have been real happy with. It was there stc built locally.
Blown56 offline
50
Blown56 wrote:Cub180 what was the cause of your vibration in your pponk motor? I have a texas skyways 0470U that I have been real happy with. It was there stc built locally.
It was his carburetor.
5186
It was carb . What I did I don't what to get in to it on this here . If some what's to know call me at 250 261-1883. The 0470u good way to go .my plane had that engine was real fuel effient. 520 just burns more fuel.i if I was to do again would go with hi rpm 470 2blade prop best bang for your buck.this was my 2 p.ponk install.other was 74 j model in 25years
Cub180 offline
92
Mon Feb 02, 2015 11:44 am
Gunny
I used a low/mid time TSIO-520P from a P210 that was in for a turbine conversion.
Steve at Pponk can tell you exactly which variations are best/easiest to use.
flyfish
flyfish offline
33
Gunny offline
394
