GumpAir wrote:Yeah, lots to be said for centerline thrust and lots of horsepower!![]()
DonC wrote:You had centerline thrust on the sleds and more HP then your cub![]()
did u ever fly the old 207 before they put the cuff on the wing ? Curvature of the earth came into play
GumpAir wrote:DonC wrote:You had centerline thrust on the sleds and more HP then your cub![]()
More like centerline get out and push....
I think I did fly the older Sleds. Barrow Air had one of the doggiest I ever flew. Loaded heavy, the only thing that saved us was ground effect and miles and miles of tundra to wallow over.
What year did Cessna change the wing?
Don't know when the 207s got the cuffed wing, but the 172s and 182s got them in 1973, FWIW.DonC wrote:GumpAir wrote:DonC wrote:You had centerline thrust on the sleds and more HP then your cub![]()
Did some research but nothing...MTV would know. But think it was in the mid 70's. Loved that old sled...we had an agreement to take care of each other and it workedGot a new one later and wow big difference
contactflying wrote:Is a wing patent forever? Do the newer Cubs, Carbon and Legend etc., use a different wing?
