courierguy wrote:Not having an airspeed indicator is no big deal if you don't know it. In other words if you don't notice it's out and you just fly the plane as usual. Once you KNOW it's out, it messes with your head!
Yes, don't fixate on the airspeed, just fly the airplane.
I entered the pattern to land behind a student in a retractable doing stop and gos. They usually sit on the runway a while, to talk about it I guess.
Anyhow, I figured no big deal I'll just pull the speed back to about 40 mph and hang on down wind while they decide to take off. I glanced at the ASI when the kitfox started to feel like about 45 mph but it said 73. It didn't sink in to me that the ASI needle was stuck so I kept slowing down until I felt the stall buffet.
I got out of the pattern to go fly around to figure it out. When I sped up the airspeed would climb above 70 but when I slowed down it wouldn't drop below 70. I figured there must be a bug in the pitot and it might be messing with my altimiter too.
I headed back to the airport to land and fixated on the altimiter this time. When I started descending to pattern altitude the ground seemed to be gitting close and I still fixated on the altimiter and the ground got even closer. Finally figured out I wasn't reading it correctly, it was working fine, I was just 1000 feet lower than my brain was seeing on the altimiter.
This time I was glad those guys were in front of me. I had time to sort out the stuck ASI. I don't pay much attention to it until I turn final then slow to 50 mph. I might have tried to slow it down more and cause a stall on final.
Here's a picture. It took me a while to see the problem. How long do you have to stare at it to see it?
