Mon Nov 20, 2017 11:47 am
Just as a data point, I had a 406 ELT that the switch failed on. I couldn’t turn it off.
I landed, manually disconnected it from the antenna, and manually turned the switch on the unit off. I returned RCCs call and they verified it was off.
I left the ELT in the back of my Cessna and went to register at OSH. Ten minutes later, RCC called again and told me the beacon was alerting again. I told them it didn’t have an antenna, and was inside a metal plane. The nice Major said stand by. A few minutes later, he came on and said “I’m plotting you about 50 to 75 meters west of runway 36 at Wittman Field, Oshkosh, WI.
And, yes, I did ask him if that was based on the first alert, with an antenna, or on the current signal. He said current signal.
The 406 signal, as noted above, goes out as a very short data burst, and as such it can be at a much higher power output than the 121.5 signal, which is continuous. The 406 signal on that unit was 10 Watts, which is pretty powerful.
406 is UHF, so antenna can be pretty small and still work. Not as well, but...
I wouldn’t bet the farm on it, but if my ELT was ripped free of antenna, I’d leave it on. I’d also find a short piece of cable or ?? And try to improve the odds.
