Backcountry Pilot • Removing Cessna 180 fuel bladders
6 postsPage 1 of 1
Hi everyone, will be replaceing the left and right fuel bladders on my 1954 Cessna 180 due to a fuel leak. Has anyone done this before and how much of a problem is it to remove them. I've heard they are a bear to remove, would like to get first hand experiance from you guys that have done it. Thiers no entry in the log book to indicate that they have been removed for repair or replaced. Any information would be greatly appreciated. Thanks
Wild Bill offline
Re: Removing Cessna 180 fuel bladders
I wouldn't say they're a bear to remove or replace, but I'd say replacing the tape is a BITCH. I did my left side and complied with the fuel vent AD & that's quite involved. If you want to pm me I'll help all I can.
Russ
Glidergeek offline
Aircraft: 1968 P206C
DG 400
I helped with mine ('56 model). Not as big a deal as I had heard. Make sure you get all the snaps in securely.
Gary
shortfielder offline
A friend of mine in Alaska had one bladder replaced on his 185. The mechanic told him he would be an hour late that morning, said he always stops by church the morning before a bladder replacement! Friend helped him and said it wasn't too bad.
sburg58 offline
Hi, I replaced both in a 185 I owned a few years back. Eagle suggested cutting them up to remove if I wasn't going to use them for cores or going to try to sell as cores, worked real well, just reached in through the opening in the wing and cut into strips with a knife. I will agree that the hardest part was removing the fuel softened glue/tape and installing the new tape. I set up a scaffold in front of the wing so that it was a comfortable height to work and covered the top of the wing with poly sheeting to protect the paint from the solvent I used to remove the old glue. Note do this with the hangar doors open to have good ventilation. I laid the new bladder out in the sun for a hour or so to warm it up before folding to fit through the opening in the wing. My plane had long range tanks which makes it easier to reach some of the snaps do to the two filler openings, and I still had black and blue marks on my upper arm and shoulder from forcing my arm into the opening to get the last snaps in the corners. While you have the bladder out take a look at the under side of the upper wing surface and the front of the tank bay, that's the wing spar, for corrosion due to condensation between the bladder and the skin. I have told several people that this is one of those jobs I would do to help a friend but not for money.
Just a job like anything else, have fun and good luck. Tim
bat443 offline
One to thank everone that responded to my question, I do greatly appreciate it. If anyone of you BCP are around Tracy feel free to stop by,just let me know when your coming. Thanks again.
Wild Bill offline
6 postsPage 1 of 1
