Again, read the charts....the CONTROLLING agency is NOT the military. They are the USING agency. When the airspace is active, the USING AGENCY controls it. When it's not, it belongs to the CONTROLLING agency, which is almost always Center.
In my experience, MOST military controllers will nearly always say NO to any civilian entry into "their" airspace. But, if it's not active, it isn't THEIR airspace. Remember, most of these controllers are pretty junior, and what's to lose if they tell civilians to go away?
Now, in the Eastern Alaska MOA Complex (which includes several large restricted areas, some of which are bombing ranges) Eielson Range Control will routinely clear you through the restricted airspace while it's notam'd hot, as long as there are no military aircraft in the Restricted areas at the moment. You'll hear them say "Belchfire 208, I've got a pair of F-16s inbound in fifteen minutes, if you can be through the restricted area by then, you're cleared through Restricted area 2202...."
If it ain't active, Center owns it. Call them.
