What we say and how we, and the authorities, interpret what is said makes a difference. Indoctrination, emphasis, and even word order lead to orientation, belief, and default.
If stall is the result of the airplane or wing exceeding the critical angle of attack, the pilot seems less responsible.
If we emphasize reduction in bank angle to mitigate load factor, we may not utilize vertical space available by allowing the nose to go down naturally.
If Vx and Vy are emphasized, ground effect may be utilized less efficiency.
If artificial horizon is considered primary, rudder to bracket directional gyro or RMI may not be used primarily. Adverse yaw may be erroneously introduced.
If aileron is considered primary, rudder to bracket the centerline or any target may not be used primarily.
I have no problem with Wolfgang's "Stick and Rudder." It sounds smoother than Rudder and Stick. His orientation was correct. Others changed that orientation to accommodate integration of instruments. He had no problem with rudder as primary and with energy management rather than just pulling back on the stick in turns.
