A few days ago I finally got around to going flying after 5 weeks and something just didn’t feel right on my rudder. The previous flight was 6-7 hours and nothing was done in the time between flights. I’m hoping that someone on here might have some insight.
Preflight flight control check was smooth and felt normal.
Once airborne I noticed that rudder pedals just felt "off" from a pressure required standpoint. One was very light to the touch and very responsive. The other was stiff. I'd apply pressure and then it would give and then be somewhat light. It was almost like taxing a taildragger: you had to take out whatever you put in. Otherwise it would stay. It wasn't self centering, if you want to put it that way. A post flight control check seemed normal.
My mechanic happened to be at the hangar when I got back and I talked to him about it. I said that other Cessnas have springs on the pedals, but wasn't sure if the 205 has them. I spent some time in the maintenance and parts manuals and talked to other 205 owners and confirmed that it doesn’t have springs. A bungee is referenced but that is only for steering on the ground. In talking to another owner, he suggested checking for anything that might be binding the controls and making sure that they are well lubricated. So today I’m going to go up, put it on it’s tail, and actuate the controls to make sure everything is moving smoothly and correctly. I’m also going to lubricate the applicable points.
Anyone have any similar experiences with something like this and know a remedy?
Thanks!
