Backcountry Pilot • Running Cold
Running Cold
3 posts • Page 1 of 1
Running Cold
Does anyone in the community have experience with the cold sump setup on a Lycoming 0-360. Is there performance to be gained in the "low level" operational enviroment, below 5000' ASL. Is it worth the effort, cost to install or just a placebo for any true performance gains
Re: Running Cold
I no input on the cold sump, however, from a increase HP standpoint with most any internal combustion engine the gains in HP mods is not cumulative. For example if you do 3 10 hp mods like exhaust, intake, and porting it will not be 30 HP gain. You will most likely only get 13-15 more HP at best. So if you already have a upgraded exhaust or porting I don't think you would see much gain. Cooler air = more O2 to the cylinder which in turn should make more power given more fuel. So how much cooler is the air/ and how does the mod affect fuel atomization and distribution? Does this cool air make for increased chance of carb ice? Still windy out today so good topic. DENNY
DENNY offline
DENNY
Re: Running Cold
I guess the reality is that other than maybe turbo charging nothing really increased HP short of increasing the volumetric capacity of the engine. So I guess it’s more about getting to the rated HP more than increasing the HP. Thoughts on that anyone, please and thank you.
