Battson wrote:Having spent yesterday at low level in the mountains, spotting deer, and also having done a little SAR now than then I would add this to the conversation:
The pilots needs to focus only on flying the plane at low level, maintaining airspeed, fuel management, engine mangement, watching for terrain, and general situational awareness. Navigation is probably possible at the same time, but if bad weather or other conditions (smoke / terrain / other aircraft traffic) increase pilot workload much, I would say flying a good grid becomes hard to do while you're doing 6 or 7 other things.
Also, one spotter can't watch two sides of the plane at once, given the pilot should not be spotting.
2c
Well I'm going to go the other way a bit, I have a little bit of time on game surveys, flying grids and never a one of those hours did we have a navigator (swans,geese,ducks,moose,sealions, whales, even salmon with tracking)? Have another couple of hours flying fire patrol spotting smokes and following a given path, not once did I have a navigator and I would say the pilot spots about 40% of the smokes, Add a couple more hours flying circuits over a forest fire with the airtach in the right seat and again with no navigator but making your track on the moving map and watching for the stray aircraft or helio that happens to be at the wrong altitude.
Search and rescue is not done at tree top level.
I think the pilot has to be involved, most of the time thats who usually knows what things look like from the air as they are usually there a whole lot more than the spotter!
I can show you where a navigator,pilot, and spotter bit it in the mountains in a 172!! They were official SAR!!
I have done a couple of hours on SAR, Only once with the official bunch that I will never fly with again!, A few were for aircraft and a couple were for ground bound winter search's, I think if you are going to find someone who is lost you need to think outside the box!! as if they were in the box, they would not be lost!!
I found the plane once, and then looked for another day to find the pilot!! he made it 3 miles from the plane!!
MHO and $.02 both way over priced!
