hotrod180 wrote:Matt, thanks for bringing up the 180 TCDS. I see that the Hartzell props all seem to have a low setting of 12 degrees. Here's the mac breakdown from the C180 TCDS::
Cessna 180 (A J & K engines)
36C-- 82": 10.5 degrees low & 22 degrees high 88" : 8 & 22
34C-- 82" 10.5 & 22 88" 10.5 & 22
(BTW when I asked Dick Jacobs at NW Prop about the 2A34C50 prop, he told me it was considered a 2A34C as per the TCDS)
C66-- 82" 10.5 & 22 88" 8 & 22
Cessna 180G & H
C201 -- 82" 13 & 24.5 88" 10.5 & 24.5
C203-- 82" 12.5 & 25 88" 10 & 24.5
I agree with Rob that props are more a black art than science.
Don't read too much into this, but I find that comment funny coming from someone with a handle like "49_sedan"49_sedan wrote:I am not a big fan of pumping lots of $ into old outdated stuff
hotrod180 wrote:As far as more performance vs just making more noise, check this page off Ponk's site.
http://www.pponk.com/HTML%20PAGES/propellers.html
It shows 940 lbs thrust for the 82" C58 prop at 2600 rpm vs 1016 for the 88" version, an increase of just over 8% -- a significant (but not huge) amount. It shows an even bigger difference between the 80" and 86 / 88" 3-bladers.
55wagon wrote:"At take off, what will your tip speed be. "
Depends on where you set your prop.
qmdv wrote:hotrod180 wrote:As far as more performance vs just making more noise, check this page off Ponk's site.
At take off, what will your tip speed be. At my ranch strip I will not let folks here with super sonic tip speed. I like happy neighbors.
qmdv wrote: At take off, what will your tip speed be. At my ranch strip I will not let folks here with super sonic tip speed. I like happy neighbors. Tim
Rob wrote:....It's my purely uneducated opinion that the reason the 88" C58/66 perform so much better than the other 88" props is due to the increased cord of the 90AT blades ......
The earlier hubs (C1, C18, C29, C50, C58, and C66) all have low blade angles in the 8.5° to 10°.5. The longer the blades, the lower the angle. The later hubs (C201/203/204) all have low blade angles at 10.5° to 13°. ....
mountainwagon wrote: As I mentioned earlier I had no prop and went with a 88 so I can wake up all the cry babies that forgot about our golden age of aviation with round engines with fat butter blades over 100" making beautiful music to kids that became pilots from that one moment.
Dad did not like that the window glazing would come loose and my mom did not like the skillet rattling on the stove.
TOOLGUY134 wrote:McCauley Seaplane Prop 88" Black Mac prop.Model 2A34C203-C. New in 2005. Low time. Excellent condition. US$ • Contact Larry , Owner - located Headingley, MB Canada • Telephone: 204-771-3997
55wagon wrote:Its for sure a strange thing these props. Flown behind several different ones. Ill catch a lot flack on this one but probably one of my favorites was a 3 blade fat paddle Hartzell. Can't recall the model off hand. Pulled like a truck. Great air brake. Easily adjusted right on the plane. Only around 80"s give or take a couple, so tons of ground clearance.
3 draw backs
Heavier. (Which my plane could use a diet anyway)
quiet. [emoji14]
And its a Hartzell.
