Mapleflt wrote:With the update from COPA spelling out the closing days of the old 121.5 kits one had to wonder what options exist other then a $1500 “investment” in a somewhat less then perfect alternative.
Yes I agree. A solid state MEMS sensor would work far better then a G switch, but i can imagine receritifying would be very costly...Mapleflt wrote:With the update from COPA spelling out the closing days of the old 121.5 kits one had to wonder what options exist other then a $1500 “investment” in a somewhat less then perfect alternative. It seems to me that a “G switch” is a feature that even the hiking, touring world could use it may come in very handy should you tumble down the hill and no longer be able to push send on your device.
Hammer wrote:Mapleflt wrote:With the update from COPA spelling out the closing days of the old 121.5 kits one had to wonder what options exist other then a $1500 “investment” in a somewhat less then perfect alternative.
I bought a 406 ELT for less than $500 US some years ago. Maybe they've gone up a bunch?
A 406 PLB won't self activate, but I guess as long as you're alive enough to warrant a rescue, you can push two buttons.
Even at $1500, not having your family wonder what happened for weeks...or years...seems pretty cheap. We are flying airplanes after all...it's not like any of us are scrounging money for groceries.
A1Skinner wrote:Hammer wrote:Mapleflt wrote:With the update from COPA spelling out the closing days of the old 121.5 kits one had to wonder what options exist other then a $1500 “investment” in a somewhat less then perfect alternative.
The cheapest I can get up here is $850 plus install cost. The problem I hve with them is the at $1500 you have no guarantee the your family will know where you are. The activation rate is still very poor. You dont have to read many accident reports to see that they often dont go off...
Sent from my SM-G960W using Tapatalk
Mapleflt wrote:So it seems we at least agree there isn’t a perfect system, so given that is a 406elt the better of all options ?
FWIW, it's not legal to hook it to a handheld GPS, and it hs to be taken to an avionics shop to hook it to a panel mount. A lot of extra $$$. I've grilled transport Canada a few times about it a few times as to why I as an AME am not allowed to hook up a single wire and makes S&R just a lot easier! But I regress...mtv wrote:Buy an ACK 04 ELT, have it installed, and have it connected to your onboard GPS, either panel mount or portable.
These units have a remote switch. Mount that front and center. When the shit hits the fan, push the button on that remote. Within 50 secons, someone in the Rescue Coordination Center will know who you are, where you are, and that you’re in an emergency.
Oh, and when you have the thing mounted, mount it according to required specs. NOT with some POS Velcro attachment, NOT on some wimpy sheet metal shelf that flexes in turbulence, NOT on a shelf that comes loose in a five G deceleration.
Want to know why so many ELTs fail to activates? Because they weren’t properly mounted.
Follow the above, properly mount the thing (it isn’t that hard), and, if the need arises, push the button prior to “landing”.
Been there, done that, ain’t that hard.
A1Skinner wrote:FWIW, it's not legal to hook it to a handheld GPS, and it hs to be taken to an avionics shop to hook it to a panel mount. A lot of extra $$$. I've grilled transport Canada a few times about it a few times as to why I as an AME am not allowed to hook up a single wire and makes S&R just a lot easier! But I regress...mtv wrote:Buy an ACK 04 ELT, have it installed, and have it connected to your onboard GPS, either panel mount or portable.
m_moyle wrote:Seems like there's this thing called Spider Tracks if you want a belt and suspenders...
I guess it's not worth losing my license and livelihood over... in reality a 406 really makes the search area very small.Hammer wrote:A1Skinner wrote:FWIW, it's not legal to hook it to a handheld GPS, and it hs to be taken to an avionics shop to hook it to a panel mount. A lot of extra $$$. I've grilled transport Canada a few times about it a few times as to why I as an AME am not allowed to hook up a single wire and makes S&R just a lot easier! But I regress...
If you're not a commercial operator, I'm curious why you'd bother following that rule...which of course you do!
Seems to be the epitome of a regulation where the punishment is irrelevant compared to the gain.
