I have a '69 C182 that I would like to install an Selkirk Extended baggage kit in.
We have a couple of items on the radio shelf behind the baggage area that need to move before it is installed (ELT and STEC autopilot pitch computer).
The ELT is easy to figure out, it will go on the sidewall somewhere.
Any suggestions about the STEC box? Does the STEC box need to be moved? If it does need to move.... where can it go? The pictures for the SA63-100 kit on the Selkirk website show that there might be some space between the shelf and fiberglass floor. The cable bundle going to the STEC box has no service loop and would probably need to be extended by an avionics shop if it will need to be moved.
Thanks for the help.
