Do you still fly the same pattern as you do learning with the instructor?
Is it rude to make it really short for practice?
I like to make it pretty small myself
M6RV6 wrote:If there is no one else there why go around the pattern, do an ag plane 180 and land going both ways??![]()
GT
hotrod150 wrote: If you read the AIM, it sez all turns to the left unless otherwise noted,
If you are at a uncontrolled airport and you are the only plane in the pattern doing touch and go's, how small of a pattern is to small?
When approaching to land. Does not apply to departures.
(a) General. Unless otherwise authorized or required, each person operating an aircraft on or in the vicinity of an airport in a Class G airspace area must comply with the requirements of this section.
(b) Direction of turns. When approaching to land at an airport without an operating control tower in Class G airspace--
(1) Each pilot of an airplane must make all turns of that airplane to the left unless the airport displays approved light signals or visual markings indicating that turns should be made to the right, in which case the pilot must make all turns to the right;
M6RV6 wrote:Original post!If you are at a uncontrolled airport and you are the only plane in the pattern doing touch and go's, how small of a pattern is to small?
FAR 91.126.(a) General. Unless otherwise authorized or required, each person operating an aircraft on or in the vicinity of an airport in a Class G airspace area must comply with the requirements of this section.
All I was trying to say is do what you want to do!
Touch and go-When you are landing it is the touch, When you depart it is the go.
If I take off as in the original post??!! And then change my runway of choice I am breaking no FARS by turning around and landing (STRAIGHT IN) on my approach to landing.
As I suggested an AG turn on departure is turn to the right a bit, then to land on the runway I just departed from, when I make my decision to land all my turns will be to the left!
If I am mistaken I very apologetic, but so far I have not seen where I am incorrect.
Agian show me the FAR that says I cannot change my runway of choice on departure!
Thanks GT
