Site issues this morning
Have a problem with the website? Maybe you can find the answer here.
Tue Jan 26, 2016 10:29 am
I implemented some new security measures last night after bots took the BCP server down 3 times with overwhelming traffic. Apparently these measures are stopping legitimate users from posting too.
I will fix it ASAP. Currently have a hungry baby in my lap.
2990
- Aircraft: None
Tue Jan 26, 2016 10:33 am
Also, if you've experienced the issue, please email me your IP address to zane@
Use
http://www.whatismyip.com so it gets you actual gateway IP.
2990
- Aircraft: None
Tue Jan 26, 2016 11:36 am
Should be working normally again. I hope.
2990
- Aircraft: None
You really need to learn to feed hungry baby and fix the site at the same time--it's called multi-tasking.
3801
Cary wrote:You really need to learn to feed hungry baby and fix the site at the same time--it's called multi-tasking.
She's getting into the fidget-midget phase as I call it. Typing with one hand while managing the baby and bottle in the other takes more brain than I'm equipped with.
2990
- Aircraft: None
Zzz wrote:Cary wrote:You really need to learn to feed hungry baby and fix the site at the same time--it's called multi-tasking.
What is it Contact says? Rub your tummy and pat your head?
Crzyivan13 offline
1811
- FindMeSpot URL: https://share.delorme.com/EvanDavis
- Aircraft: 1957 Cessna 182A
With fidgety babies use proactive dynamic fidget technique to get ahead of them. Giggle, yell, scream, make faces, etc. dynamically and proactively to capture and direct their attention. Oh, and type with the other hand.
Thanks Zane for setting up my signature thing at the bottom.
4972
Zane blaming the 'bots' then playing the 'hungry baby card' again. I call BS. It was porn and spilt beer that caused all this mess.
akgreg offline
484
- Aircraft: Yes
Thu Jan 28, 2016 12:43 am
hey I'm busy conducting website theater here, back off big Greg.
Thanks to all who emailed me your IP addresses to help troubleshoot the issues. It definitely helped.
2990
- Aircraft: None
