hardtailjohn wrote:The last one I did, we put a "fish pole" tube in, aft of the baggage and at an angle. You could put skis and poles in through the baggage door. I've seen them setup with a small door on the aft cabin wall, on one side or another, so you could access it through the cabin, but we couldn't do that because of the fuel tanks between the cabin and baggage.
VortexAlternator wrote:Thanks for all the support! I'm glad you are enjoying it.
I'm planing to add a long cargo tube for sure.
Right now I'm working on the strut fairings. This is my first attempt so it's a little rough. The originals are just strut shaped tubes cut off at a 26 degree angle to cover the strut ends and attachment points. I'm going to make proper aerodynamic fairings. I'm making the diameter of the fillet about the same as the thickness of the strut. I found a paper showing the majority of the interference drag of a pair of parallel streamlined shapes drops off once it's one thickness apart from it's neighbour.
I'm hoping to find the optimal fillet diameter that results in the lowest drag as a trade off between increasing the frontal area and reducing the interference drag. If anyone has links to good info on strut fairing design, I'd be grateful. NACA has a basic one that's not super helpful.
VortexAlternator wrote: These are .187” thick but I wish I could use .125” to save weight. The 337 on these specifies .187. Anyone know if there are other aircraft with similar size one piece windshields in .125”?
So, you must be handy with a planishing hammer and English wheel?
I did bubble side windows on one as well.
