Update time. Been busy with everything as usual but fit some time in there for the Skook.
I had to let the mount marinate in my brain for a while before continuing. Deciding on the swing out or not situation was finally concluded with a yes. You can see how close to the firewall I’m going but my accessory case has been gradually depopulated to the point where all
I have on there is the Airwolf remote filter adapter. I just made the decision to turf the vacuum system and gauges but I’m considering adding a back up alternator on that pad as I have a dual plasma EFI so electrical redundancy is pretty darn important. Anyway, here’s the mount so far.
A little rotary table work makes for such a nice radius.
Mount hinges are 0.128 4130 and will have a web welded on both sides to box them otherwise that bend radius would be too small by itself.
My notcher is a cheapo unit from Princess Auto that can’t cut shallow angles so I had to set these up on the lathe. Very satisfying to cut compared to a drill and a hole saw.
Some unboxing now… hmmmm. what’s this mysterious metal for the firewall?
What time is it?!? Got have some extra steam to make up for the loss of the AI.
A succulent serving of servo.
And the darn home wrecker breaking up the six pack:
And just because I can, so you may enjoy, a Canso. It was parked at Bounday Bay for some filming. How could I resist?
