Skywagon gear leg outer bracket.
[email protected] wrote:AEROPOD wrote:limerick wrote:IMG_2822.JPG
"Carefully" imparting tons of stress in to a part beyond what it was designed for is no less likely to damage it than imparting the stress like a butcher. It seems like a a lot of work, just to avoid a lot of work.
Like i tell my kids, a lot of times the hard way and the right way are the same way.
Thx Aeropod. Any chance for you to share some pics when doing it from underside pls?
Sure, I’ll gather some up tomorrow.
AEROPOD offline
479
I did a lot of research on how to replace the MLG brackets and made the decision to remove from the inside. I had NO cracks on the angle bends but riveted the angle brackets under the bent angle to beef it up. Every drilled out rivet was replaced with AN rivets installed with a pneumatic squeezer or bucking. No Cherry Max rivets were used. I spent two months + on this project and avoiding work never entered my mind. I need to spend some time to figure out how to post the pix because the two I posted gave me an error message that the way I added the pix was not how to add.
limerick offline
83
- Aircraft: Cessna 180 Skywagon
Tue Mar 28, 2023 10:14 pm
Deleted
limerick on Wed Mar 29, 2023 9:28 pm, edited 2 times in total.
limerick offline
83
Been down this road... I've come to the conclusion that cutting the angles or misforming any structure is not considered best practice.
As Sam mentioned, bending will induce cracks that may or may not be visible.
Bigrenna on Sat May 06, 2023 6:29 am, edited 1 time in total.
2339
- Aircraft: C180H / C170B
www.avthreads.com
limerick wrote:…how to post the pix because the two I posted gave me an error message that the way I added the pix was not how to add.
You probably used the attachment method, which works fine. I simply added a note to inform people that there is a better recommended way. You can use either.
2855
For those who have opened the underside, any chance to see some pics?
Looks like one of the panels that has to be taken out goes all the way to the other side of the fuselage....
[email protected] offline
151
limerick offline
83
limerick offline
83
limerick offline
83
limerick offline
83
limerick offline
83
limerick offline
83
limerick offline
83
limerick offline
83
limerick offline
83
limerick offline
83
limerick offline
83
limerick offline
83
limerick offline
83
- Angles bent back into position with crescent wrench slowly and carefully. Angle doublers added under each of the bended areas and riveted horizontally with pneumatic squeezer. The floor sheet metal was riveted thru both the bent angle and the added angle doubler vertically for strength.
limerick on Wed Mar 29, 2023 9:52 pm, edited 1 time in total.
limerick offline
83
