Rob wrote:rw2 wrote:... So you would get less than one charge from Guide10.
iPad is 11,000mah. So Guide10 wouldn't even make a dent in that.
Not to be argumentative... but again, if you are of the mindset that you want it all, and you want it now.... solar is not for you... on the other hand if your patience and reasoning / logic skills surpass that of your battery
then solar should work out just fine. By the above reasoning all aircraft electrical systems are worthless because they can't sustain full loads (including the starter) perpetually...
Yeah, I get that you're not being argumentative. Hopefully I'm not coming off that way either. I'm just saying why *I* don't think there is strong value in a solar based setup on either a per-ounce or per-dollar basis at the moment. And I don't think it is a "want it all/want it now" argument. Yes, solar can work. I don't mean to say it can't. But, it's a very expensive way to get the job done.
Dollar for dollar, you can take far more electrons into the field by getting multiple battery packs. Ounce for ounce you have to stay in the bush with no access to power for a week or more before solar starts to make any sense at all. And those are both true whether your bringing a single point and shoot camera or several gopros. Solar panels are just not very efficient and to get enough capacity to gather enough light they get heavy. So if you need a lot of electrons, solar and batteries both get heavy. If you don't need very many then solar and batteries both stay light.
The goal10 + solar panel is within an ounce or two of the same weight as the 13,000mah battery I linked initially. So here are the two scenarios. I'm walking into the woods with the same weight and either 13,000mah (battery pack) or 2,000mah(guide10+solar).
The Nomad 7 produces 1,000mah under optimum sun. Having lived off a solar panel in a pop-up trailer for a few summers, I can pretty much promise you that you won't have optimum sun. First, no one sets up camp in the sun. Second, you have to adjust the panel to get optimum sun. Since you'll be out hiking all day, even if you leave the panel in the sun before you leave it won't alway be optimum. Even the vendor says you can plan on getting one charge per day, or 2000mah out of the setup.
The best case scenario in favor of solar would be one where you are using 2000mah a day of juice and thus giving you infinite power from solar (assuming, on top of our previous assumptions, that it never gets cloudy) while wearing out the big battery pack most quickly. At 2000mah per day the big battery runs out halfway through the sixth day while the solar system keeps supplying forever.
Let's say you are using more juice than that. Let's say you are using double that. In that case the big battery runs out the morning of the third day. Not too great. However, the solar solution only lasts a single day, then you are on half power.
Let's say you use half that. Then the big battery lasts about two weeks. The solar solution again lasts forever, but you don't care until day 14. And, of course, you got to spend the last two weeks managing a solar panel. I suppose the most likely scenario where I'm in the bush for two weeks is one in which I'm doing a through hike. Solar panels would be terrible for that as you can't set them up in a sunny spot in the morning and then come back. It would have to be mounted atop your pack somehow and, if you're anything like me, you don't hike the entire day in the sun if you can avoid it.
But we still have to get back to cost. In all those scenarios that big battery costs me less than a quarter of what the solar system cost and weighed the same.
To me all of this is a bit academic though. I think the case against solar is very strong for 98% of backpackers, but this is an airplane forum, so I'm concerned about pounds more than ounces. So, to me, "wasting" three pounds on three of the big batteries and having all the power I could need is very appealing. Then I don't have to budget my video time. Heck, when I did my homework earlier and saw the capacity of modern boat and solar batteries I was half tempted to get one. I can get a 225,000mah solar battery for $175 and it weighs 67 pounds. Under the 4,000mah scenario above that would give me almost two months of power.
Then I remembered that I've never actually been away from power for more than three days.
For my use case, the $50 battery is an absolute no-brainer.
If you're going to be using some power, but not a lot, and are in the bush for more than a week then solar starts to look appealing.
If you are going to use a lot of power, then you need to be very strong, because your backpack is gonna get heavier no matter what and you're going to look goofy with a 70W solar panel on your head if you try to go solar.
If you aren't going to use much power then batteries will last you longer than you need and be tons cheaper.
