An airplane that is somewhat short on fuel endurance is the PERFECT candidate for a fuel flow computer. I don't care who you are, if you fly much, and you fly a range challenged airplane, sooner or later, you are going to get into fuel issues.
The fuel flow computer really helps to mitigate those circumstances, and gives you a better handle on what's going on.
You ask the question: How many different power settings do we have to experiment with before we settle on one we use? Words to that effect, anyway. Too lazy to actually cut and paste.
I ALWAYS use different power settings. Like almost every time I fly. Assuming I have a fuel computer, that is.
You are proud of your clean plugs, but you could well be frying a valve in the process of running those clean plugs. The leaner they get, the cleaner they burn. Right up to big bucks.
I'd rather know what is going on with the atmosphere and my airplane, than worry about clean plugs.
I'd rather clean the plugs every 50 hours (which I do regardless) than lean the hey out of an engine and fry a valve.
Been there, done that, with a single probe egt, and poor leaning practices.
